Component: Electrical Machines (AllCode)
| Version | 2.0 (Release) |
| Category | AllCode |
A set of functions to communicate with the Matrix EM hardware. Allows the functions to be easily standardised across all SCADA programs.
This component does not contain any downloadable macros
Simulation macro reference
GetLogDataReady
Checks to see if the logging is complete and ready to read.
- BOOL : Returns true if the operation is a success, else false
GetRPM
Reads the speed in RPM
GetWeight
Reads the voltage of a single channel
- BYTE Scale
- Range: 0-1 - 0=Weight, 1=Torque
SetControlKP
- FLOAT Value
SetControlSetpoint
- FLOAT Value
GetAPIVersion
Reads the API firmware version
GetLogData
Gets a 64-byte packet of log data. 250 packets make up a single log.
Returns 0 if comms failed and 1 if comms OK
- BYTE Buffer
- Buffer to store the incoming log data
GetDataArray
Collects a data array from the EM box full of control data.
Each set of data includes:
Setpoint, Feedback, Poutput, Ioutput, Doutput
Returns the number of complete data samples collected.
- FLOAT data
GetSafetySwitch
Reads the safety switch
SetControlKI
- FLOAT Value
ZeroLoadCell
SetControlMaxDrivePercentage
- FLOAT Value
- Range 0.0-1.0
SetMotorType
- BYTE MotorType
- 0=DC, 1=1 Phase, 2=3 Phase
SetLoadCellCalibration
- FLOAT Value
GetVoltage
- BYTE Channel
- Range: 0-5 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=VEXT
GetControlFeedback
SetControlKD
- FLOAT Value
SetCapacitorBank
- BYTE Cap
GetCommsOK
Checks if comms are ok and stable
GetLogStartAngle
Collects the U Phase angle at the start of logging.
Used to calculate and re-create the 3Phase voltage data.
SetVoltage
Sets the DC Voltage from 0 to 24V
- FLOAT Voltage
- BYTE Index
Get3PhaseMode
Checks to see if the brushless mode is enabled
GetAbsPosition
Reads the absolute position of the encoder
SetFan
|Sets the speed of the FAN from 0 (MIN) to 3000 (MAX)
- UINT Speed
SetMotorDirection
- BOOL MotorDirection
- 0=FW, 1=BW
GetMotorDirection
Reads the motor direction
SetThreePhaseDriveMode
- BOOL Mode
- 0=Simple, 1=Accurate
GetCurrent
Reads the current of a single channel
- BYTE Channel
- Range: 0-6 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=Dyno, 6=I, 7=TotalDriver
SetFrequency
- UINT Frequency
- Frequency of sine wave in Hz
SetDynoLoad
- FLOAT Load
GetErrorStatus
Gets the current error status.
Error status will automatically resolve itself once the causing condition has been removed.
0 = No Error
1 = Error - likely over current or brownout
GetControlOutputs
- FLOAT Data
SetActive
- BOOL Active
- 0=Off, 1=On
SetDriveMode
- BYTE Mode
- 0=PWM, 1=On/Off/Float
SetTCPProps
Sets the TCP IP address and Port
- BYTE IP0
- BYTE IP1
- BYTE IP2
- BYTE IP3
- UINT Port
SetAbsPosition
Resets the absolute motor position to 0
Returns 1 if the connection is ok and communications have been established
- BYTE MotorType
- 0=DC, 1=1Phase, 2=3Phase, 3=AngleControl
Comms Mode
This property is of type Fixed list of ints and can be referenced with the variable name CommsMode.
Stop On Error
This property is of type True or false and can be referenced with the variable name StopOnError.
Automatically allows the runtime to stop if there is a communications error.
Autodetect Port
This property is of type True or false and can be referenced with the variable name AutoDetect.
Network Interface
This property is of type Fixed list of ints and can be referenced with the variable name NetworkComms1::NetworkInterface.
Some computers may have several network interfaces such as ethernet ports and wifi access.
Select the correct network interface for the network you wish to connect to.
Use the IP address to confirm you are connected to the right network.
IP Address
This property is of type Line of text and can be referenced with the variable name NetworkComms1::IPAddress.
IP Address of the selected network interface.
EM Box IP Address
This property is of type Line of text and can be referenced with the variable name BoxIP.
EM Box Port
This property is of type Unsigned integer and can be referenced with the variable name BoxPort.
This property is of type True or false and can be referenced with the variable name ConsoleData.
Allow console data to be generated showing the high level EM communications and returns
