Component: UART SCADA (CAL) (Misc)
Revision as of 16:17, 7 January 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 2.1 |- | width="20%" style="color:gray...")
Version 2.1
Category Misc
UART SCADA component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the UART peripheral. Includes simulation functionality to commmunicate via a COM port or an Injector component. Also includes timestamped logging via the console and Data Recorder trace monitoring support.
FREE
SendString
Transmits a string of bytes via the UART peripheral
- STRING Data
Data String to transmit
Receive
Receive a Character
- UINT Timeout
Period to wait for the character to be received
- INT Return
ScanForDeviceID
Checks to see if a device VID/PID string is present and returns the COM port number. Returns 0 if device not found.
- STRING HWID
Example: "VID_12BF&PID_0101"
Send
Send the Character
- UINT Char
The Character to send
GetConsoleHandle
- HANDLE Return
SendByteArray
Transmits an array of bytes via the UART peripheral
- BYTE Data
Data to transmit
- UINT NumBytes
Number of bytes to send from the array
Init
Initialize the component with the specified properties
Uninit
Un-initialize the UART and release the resources
ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
- BYTE Data
A byte array variable to hold the received data
- UINT NumBytes
Maximum number of bytes to try and receive
- UINT Timeout
Max amount of time in ms to wait between bytes
ReceiveString
Receives a string of bytes and returns the number of bytes received.
- STRING StringData
- UINT NumBytes
- UINT Timeout
Component Enable
A global flag to enable or disable the UART component from producing code. Useful for generating components with multiple communications options.
Console Columns
Auto Close
Auto close the port on Sim stop event
Data Source
COM Port
Lists all the current available COM port hardware on your PC.
Refresh Ports
COM port data rate in bits per second
Simulations
