Component: Temp / Humidity (Grove 101020019) (101020019) (Environmental)
| Version | 1.2 |
| Category | Environmental |
Temp / Humidity (Grove 101020019) component
The DHT22 temperature and humidity sensor is a popular sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 0% - 100% +/- 2% Temperature Range = -40 - 80 Degrees C +/- 0.5 Degrees C
SENSORS
| GetTempWhole | |
| Gets the whole number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 15. | |
| GetHumidityFloat | |
| Gets the humidity returned by calling SampleSensor as a floating point number. If humidity is 15.8 % then this function would return 15.8. | |
| GetTempString | |
| Gets the temperature returned by calling SampleSensor as a string. If temperature is 15.8 degrees C then this function would return "15.8". | |
| GetHumidityString | |
| Gets the humidity returned by calling SampleSensor as a string. If humidity is 15.8 % then this function would return "15.8". | |
| GetHumidityWhole | |
| Gets the whole number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 15. | |
| GetTempReal | |
| Gets the real number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 8. | |
| GetHumidityReal | |
| Gets the real number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 8. | |
| SampleSensor | |
| Communicates with the DHT11 sensor and receives the temperature and humidity readings. Returns 0 for success, 1 for no communication detected and 2 for checksum error. | |
| GetTempFloat | |
| Gets the temperature returned by calling SampleSensor as a floating point number. If temperature is 15.8 degrees C then this function would return 15.8. | |
