Component: BBC Weather Observation (Comms: IoT/Cloud)
Revision as of 16:20, 7 January 2022 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: IoT/Cloud
BBC Weather Observation component
Easily allows you to collect observed weather metrics for your area using the BBC Weather data service. Supports temperature and humidty for your selected area. Also available are Wind Direction, Wind Speed and Air Pressure but please note these are not always available depending on your selected area.
COMMSC
Here is a basic example to read the observation data and report the information on a graphical display.
BBCWeatherDemo
The location can be set by adjusting the BBC Weather location property, see the component property tooltips for more information on how to do this.
On an embedded device you would need a TCP/IP component to allow the communications to the BBC server. This then links to the Network Comms component.
GetWindDirection
Reads the reported wind direction as a string. Please note this data may not be available for your selected location.
- STRING Return
RequestData
Requests data about your selected location from the BBC weather service. Returns true if the request was successful. Must be called before trying to call any of the GetXXX macros.
- BOOL Return
GetHumidity
Reads the reported humidity in Relative Humdity.
GetTemperature
Reads the reported temperature in the selected scale.
- BOOL Scale
0 = Celcius, 1 = Farenheit
- INT Return
GetWindSpeed
Reads the reported wind speed in MPH. Please note this data may not be available for your selected location.
SetLocationCode
Allows the location code to be altered from the default location code set in the component properties. After changing the location the RequestData macro must be called to refresh the forecast variables.
- STRING NewLocation
New location string, see Location property tooltip for more info.
GetPressure
Reads the reported air pressure in milli bar (mb). Please note this data may not be available for your selected location.
GetLocationName
Reads the reported location name as a string.
- STRING Return
Sets up the component ready to collect weather data.
Network Comms Component
Network Communications component to use as the bridge to the TCP/IP network.
BBC IP Address
IP Address linked to the following URL: weather-broker-cdn.api.bbci.co.uk
Location Code
BBC code for your area. In a web browser go to www.bbc.co.uk/weather/ Then type in your city in the search bar and your code will be shown at the end of the URL. For example Manchester in the UK = 2643123 In the UK you can also use the first half of your post code, e.g. HX1
Receive Timeout
Maximum time to wait for valid incoming data.
Simulations
