Component: Keypad (4x4) (Keypad)
Revision as of 16:20, 7 January 2022 by Wiki bot (talk | contribs)
Category Keypad
Keypad component
Preset keypad based around the 4 * 4 unit.
BASICIO
WaitPressed
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user.
GetAscii
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255.
GetString
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns the value 255.
- STRING Return
GetNumber
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255.
GetIndex
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255.
WaitReleased
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley.
Column 1
Pin for the first column of keys. Columns are counted from left to right.
Column 2
Pin for the second column of keys. Columns are counted from left to right.
Column 3
Pin for the third column of keys. Columns are counted from left to right.
Column 4
Pin for the fourth column of keys. Columns are counted from left to right.
Row 1
Pin for the first row of keys. Columns are counted from top to bottom by default - they can be counted from bottom to top by changing the 'First Row' property in the 'Dimensions' section.
Row 2
Pin for the second row of keys. Columns are counted from top to bottom by default - they can be counted from bottom to top by changing the 'First Row' property in the 'Dimensions' section.
Row 3
Pin for the third row of keys. Columns are counted from top to bottom by default - they can be counted from bottom to top by changing the 'First Row' property in the 'Dimensions' section.
Row 4
Pin for the fourth row of keys. Columns are counted from top to bottom by default - they can be counted from bottom to top by changing the 'First Row' property in the 'Dimensions' section.
Simulations
