Component: RFID (MFRC522) (Wireless)
Revision as of 16:20, 7 January 2022 by Wiki bot (talk | contribs)
Author Ben Rowland and STibor
Version 3.0
Category Wireless
RFID (MFRC522) component
Functions designed to work with the MFRC522 contactless reader IC. The MFRC522 supports all variants of the MIFARE Mini, MIFARE 1K, MIFARE 4K, MIFARE Ultralight, MIFARE DESFire EV1 and MIFARE Plus RF identification protocols.
COMMSC
Here is a basic example program that reads the UID from a Mifare RFID tag and displays on an LCD. If the UID matches the UID stored in memory then a solenoid will fire allowing a door to be unlocked etc.
Display UID
Here is a basic example program to read and modify data stored on a Mifare RFID tag.
Read Write Test
CompareUID
Compares the UID from the ReadCardSerial macro with 4 byte UID. Returns 0 if the addresses match.
- BYTE Add0
- BYTE Add1
- BYTE Add2
- BYTE Add3
IsNewCardPresent
Is there a card present for us to communicate with. Returns 0 for no card and 1 for valid card present.
GetType
Translates the SAK (Select Acknowledge) to a PICC type
- BYTE sak
The SAK byte returned from PICC_Select
AntennaOff
Switches off the RFID antenna to save power. The antenna must be switched on again before communicating with an RFID tag.
ReadCardSerial
Simple wrapper around PICC_Select. Returns true if a UID could be read. Remember to call PICC_IsNewCardPresent(), PICC_RequestA() or PICC_WakeupA() first. The read UID is available in the class variable uid.
MifareWrite
Writes to a block of data on a MIFARE type tag
- BYTE BlockAddress
- BYTE Buffer
- BYTE BufferSize
Select
- BYTE ValidBits
StopCrypto
Used to exit the PCD from its authenticated state. Remember to call this function after communicating with an authenticated PICC - otherwise no new communications can start.
MifareRead
Reads from a block of data on a MIFARE type tag
- BYTE BlockAddress
- BYTE Buffer
- BYTE BufferSize
Authenticate
This command manages MIFARE authentication to enable a secure communication to any MIFARE Mini, MIFARE 1K and MIFARE 4K card. All keys are set to FFFFFFFFFFFFh at chip delivery. The authentication is described in the MFRC522 datasheet section 10.3.1.9.
- BYTE Command
PICC_CMD_MF_AUTH_KEY_A or PICC_CMD_MF_AUTH_KEY_B
- BYTE BlockAddress
The block number
- BYTE Key
Crypteo key to use
HaltA
Instructs a PICC in state ACTIVE(*) to go to state HALT
ReadUIDByte
- BYTE Index
0-9 = UID Data Bytes, 10 = UID Length, 11 = UID SAK
AntennaOn
Switches on the RFID antenna. Called as part of the Initialise macro.
Initialises the RFID module ready for interaction with RFID tags.
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Reset
MFRC522 Reset Pin
Simulations
API
