Component: API (Arduino Uno) (API Slave Devices)
| Version | 2.0 |
API (Arduino Uno) component
Connects to an Arduino Uno running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM See Flowcode Help Wiki for firmware.
FREE
The App Developer (Arduino Uno) component allows an Arduino Uno board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Arduino Uno hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
Arduino Uno App Developer Firmware
The COM port to the Arduino hardware is selected via the App Developer_Ard_Uno componennt COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
- fixed statistics showing IO / ADC inputs / PWM
- scrolling log showing all commands and returns
Pin Mapping
| App Developer Slave Digital Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 |
| Device Port Pin | D0 | D1 | D2 | D3 | D4 | D5 | D6 | D7 | B0 | B1 | B2 | B3 | B4 | B5 | C0 | C1 | C2 | C3 | C4 | C5 |
| Arduino Style Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | A0 | A1 | A2 | A3 | A4 | A5 |
| App Developer Slave Analogue Pin | 0 | 1 | 2 | 3 | 4 | 5 |
| Device Port Pin | C0 | C1 | C2 | C3 | C4 | C5 |
| Arduino Style Pin | A0 | A1 | A2 | A3 | A4 | A5 |
| App Developer Slave Peripheral Pin | I2C SDA | I2C SCL | SPI MOSI | SPI MISO | SPI SCK | PWM 0 | PWM 1 | PWM 2 | PWM 3 | PWM 4 | PWM 5 | OneWire | Servo 0 | Servo 1 | Servo 2 | Servo 3 | Servo 4 | Servo 5 | Servo 6 | Servo 7 |
| Device Port Pin | C4 | C5 | B3 | B4 | B5 | D6 | D5 | B1 | B2 | B3 | D3 | D2 | D2 | D3 | D4 | D5 | D6 | D7 | D8 | D9 |
| Arduino Style Pin | A4 | A5 | 11 | 12 | 13 | 6 | 5 | 9 | 10 | 11 | 3 | 2 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 |
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5.
Rapid Development - Virtualised SPI
A feature of the App Developer Slave interface is to use the component for rapid development.
The App Developer Slave hardware can be used to take communications from the Flowcode simulation and transfer them to a real world device allowing for easy code generation and test without having to download to a target microcontroller device.
The CS pin and SPI Prescaler are set via the properties of the Injector component.
The SPI Master component is linked to the Injector component via the Injector property.
The Injector component is linked to the App Developer Slave component via the App Developer Slave property.
Arduino Uno App Developer Slave SPI Demo
Rapid Development - Virtualised I2C
The I2C Master component is linked to the Injector component via the Injector property.
Arduino Uno App Developer Slave I2C Demo
Rapid Development - Virtualised UART
The Baud rate and optional RS485 Properties are set via the properties of the Injector component.
The UART component is linked to the Injector component via the Injector property.
Arduino Uno App Developer Slave UART Demo
| I2CInitialise | |
| Initialsie the I2C module ready for communications | |
| Channel | |
| Baud | |
| IOGetInputPin | |
| Pin | |
| Range: 0-19 | |
| OneWireInitialise | |
| Initialise the OneWire module ready for communications | |
| Channel | |
| ADCSample8 | |
| Reads the voltage present on an Analog pin as an 8-bit value range 0-255 | |
| ADCChannel | |
| Range: 0-5 | |
| RegisterWrite | |
| Writes to one of the registers on-board the device | |
| RegisterAddress | |
| The address of the register | |
| Data | |
| The data value to assign to the register | |
| RegisterRead | |
| Read one of the registers on-board the device | |
| RegisterAddress | |
| OneWireTransmitByte | |
| Transmit a byte to the one wire bus a bit at a time | |
| Channel | |
| Data | |
| I2CRestart | |
| Put the I2C Module into Restart mode | |
| Channel | |
| PWMDisable | |
| Disable a PWM output | |
| Channel | |
| Range: 0-5 | |
| I2CStart | |
| Put the I2C Module into Start mode | |
| Channel | |
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Channel | |
| Last | |
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
| ADCSetReferenceVoltage | |
| Specified the reference setting for ADC reads. | |
| RefType | |
| 0=AREF, 1=VCC, 3=Internal 1.1V | |
| OneWireSkipROM | |
| Performs a bus reset and the sends the SkipROM command byte | |
| Channel | |
| ServoDisable | |
| Disable a Servo output Ch0 to 7 = Pins 2 to 9 | |
| Channel | |
| Range: 0-7 | |
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
| ServoEnable | |
| Enable a Servo output Ch0 to 7 = Pins 2 to 9 | |
| Channel | |
| Range: 0-7 | |
| PWMSetDuty | |
| Sets the duty for the PWM output | |
| Channel | |
| Range: 0-5 | |
| Duty | |
| ADCSample10 | |
| Reads the voltage present on an Analog pin as an 10-bit value range 0-1023 | |
| ADCChannel | |
| Range: 0-5 | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-19 | |
| State | |
| Range: 0-1 | |
| ServoSetPosition8 | |
| Sets the position as an 8-bit value Ch0 to 7 = Pins 2 to 9 | |
| Channel | |
| Range: 0-7 | |
| Position | |
| Range: 0-255 | |
| OneWireScanBus | |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
| Channel | |
| SPIInitialise | |
| Channel | |
| OneWireReceiveByte | |
| Receives a byte from the one wire bus a bit at a time | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| OneWireGetDeviceCount | |
| Returns the number of devices found by the last ScanBus operation. | |
| Channel | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Range: 0-5 | |
| Prescaler | |
| Period | |
| Default 255 | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-5 | |
