| Author
Matrix Ltd
| Version
1.1
| Category
Magnetic
Hall Effect Digital component
Simple digital hall effect on off switch triggered by the proximity of another object.
SENSORS
Sample program using the EBM011 - Hall Effect sensor
Reads the sensor and displays output on LED D7.
EBM011 Example
ReadState
| Get the current collision state. The 'Polarity' property will affect whether a collision is represented by a high or low state.
- BYTE
SetTarget
| Set the object that you want to test for collision with. If this is not called, or is called with handle = 0, collisions will be tested against every panel object that has 'Solid' status. NB) Specifying an object will save CPU power!!
- HANDLE
Target
| The object to test for collision with.
WaitUntilHigh
| Pause the program until the detector goes high. 'Polarity' will affect whether high value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!!
WaitUntilLow
| Pause the program until the detector goes low. 'Polarity' will affect whether low value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!!
Pin
| The chip pin that will receive the switch status.
Polarity
| Select the pin state that will indicate that an object has been detected.
Simulations
Magnet Object
| Select an object from the panel to act as the magnet that triggers the reed switch.
Range
| Distance within which the switch is activated. NB) This is measured between the centre of the proximity switch and the centre of the target object.
Timer Interval (ms)
| Time in milliseconds between testing for proximity. Small time = Greater CPU load Large time = More like to miss activation if it is very brief.
