Component: Range Time of Flight (VL53L0X) (Light)
| Author | MatrixTSL |
| Category | Light |
Range Time of Flight (VL53L0X) component
A laser based range sensor designed to provide accurate range infomation for a very narrow sensing beam. Capable of sensing ranges from 50mm to 1200mm. Communication with the device is based on a I2C bus.
FREE
Simple example showing the proximity detector component at work, when a proximity is detected the direction of the motor is reversed.
Detector
| ReadModel | |
| Collects the model number from the sensor | |
| ReadRevision | |
| Collects the revision number from the sensor | |
| ReadDistance | |
| Read the current distance in mm. Returns -1 if the sensor timed out during the read operation. | |
| ReadRegister | |
| A simple example showing a generic way to read a register using I2C. | |
| Address | |
| WriteRegister | |
| A simple example showing a generic way to write a register using I2C. | |
| Address | |
| Data | |
