Component: Thermistor (Environmental)
| Version | 1.1 |
| Category | Environmental |
Thermistor component
A generic thermistor component that can be used to simulate and create code for any thermistor with a known temperature/resistance curve. Thermistor is connected in a simple potential divider circuit - thermistor between ADC input and 0V, and a fixed resistor between ADC and the positive supply. Default calibration is for the EBM003 module.
SENSORS
| GetIntegerTemperature | |
| Reads the ADC input and returns the calculated Temperature as Integer degrees C | |
| SetChannel | |
| Set the ADC Channel | |
| ChannelID | |
| SetMinMax | |
| Set the minimum and maximum temperature values that can be shown and set on the thermometer readout. | |
| Min | |
| Minimum Value | |
| Max | |
| Maximum Value | |
| GetRealTemperature | |
| Reads the ADC input and Returns the calculated Temperature as Float value in degrees C | |
| CalculateTemperature | |
| Converts the input ADC value and returns the Temperature in tenths of degree C | |
| ADCValue | |
| ADC Reading to be converted | |
| GetADCValue | |
| Returns the Raw ADC value from the Analogue Channel | |
