Component: Potentiometer (Trimmer) ()
Revision as of 16:27, 7 January 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.4 |- | width="20%" style="color:gray...")
Version 1.4
Category
Potentiometer (Trimmer) component
Trim Pot for 0.1mm pitch PCB. With finger dial knob. Pointer colour can be changed from component properties.
BASICIO
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Simulations
Start Angle
Sweep Angle
Color
