Component: GLCD (SSD1289) (Graphical Color)
Revision as of 16:28, 7 January 2022 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Color
GLCD (SSD1289) component
Graphical display component based on the SSD1289 16-bit colour graphical controller IC.
DISPLAYS
ReadFontWidth
- BYTE Font
- BYTE Character
BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
FastPlot
SetDisplayOrientation
- BYTE Orientation
BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BPlot
- UINT X1
- UINT Y1
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Pixel Width
Pixel Height
Monochrome
Foreground Color
Background Color
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Chip Select (CS)
Chip select pin connection
Reg Select (CD)
Read (RD)
Reset pin connection
Write (RW)
Data Port Low
Data Port High
Simulations
