Component: Formula Flowcode (Robotics)
Revision as of 16:29, 7 January 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 2.0 |- | width="20%" style="color:gray...")
Version 2.0
Category Robotics
Formula Flowcode component
A component to allow all the features of the Formula Flowcode robot to be investigated. Fully simulated component which can interact with simulated objects on the panel as well as control the real hardware.
FREE
Importing from v5
The Formula Flowcode component in Flowcode v6 has a new Initialise macro which will need to be added to your program before any other calls to the component are made.
Line Following
Line following example using the Formula Flowcode, works with objects on the simulation panel and on the real hardware. FF-Line
Maze Solving
Wall following example using the Formula Flowcode, works with a randomly generated maze on the simulation panel and on the real hardware. FF-Maze
PlayNote
Outputs a single tone from the onboard speaker for the period specified
- BYTE Note
- UINT Delay_ms
LEDOn
Switches on a single LED on the front of the Formula Flowcode.
- BYTE LED
Stop
Stops both motors
LEDOff
Switches off a single LED on the front of the Formula Flowcode.
- BYTE LED
ReadMic
Reads the current audio signal level from the on-board microphone.
- INT Return
ReadSwitch
Reads the value of one of the switches from the front of the Formula Flowcode.
- BYTE Switch
SpinLeft
Spins the formula flowcode on the spot in an anticlockwise direction as seen from above.
- BYTE Power
Forward
Drives both motors of the formula flowcode forwards with the power specified.
- BYTE Power
ReadLineSensor
Returns the digital value from the line sensor specified.
- BYTE Sensor
SpinRight
Spins the formula flowcode on the spot in a clockwise direction as seen from above.
- BYTE Power
CheckIR
Checks to see if a IR sensor is within the master threshold distance.
- BYTE Sensor
ReadIRSensor
Reads the analogue value from the specified IR distance sensor.
- BYTE Sensor
SetMotors
Sets the speed and direction of the Formula Flowcode motors.
- INT Left_Power
Valid Range = -255 to 255
- INT Right_Power
Reverse
Drives both motors of the formula flowcode backwards with the power specified.
- BYTE Power
WaitForSwitch
Waits for the specified switch to be pressed.
- BYTE Switch
ReadLDR
Reads the current audio signal level from the on-board light sensor.
- INT Return
WriteLEDs
Allows control of all 8-LEDs on the front of the Formula Flowcode.
- BYTE LED_Byte
Starts up the formula flowcode PWM for motor control and performs the wait for button press
Wait For Button
Determines if the program will automatically wait for one of the front switches to be pressed before executing the program.
IR Sensitivity
InfraRed read mode - 8-bit or 10-bit
Motor Balance (-100 - 100)
Motor balance, way of modifying the relative speeds of the motors to allow mismatched motors to work together better.
Left
IR Threshold used with the CheckIR macro
Front
Right
Sim Speed (1 - 100)
Sets the simulated amount of movement relative to the speed of the formula flowcode
Smooth Animation
Selects if the simulation has additional smoothing going on in between iterations
Manual Redraw
Sets if the animation forces it's own redraws or waits for the system to perform a redraw
Timer Interval (ms)
Interval in ms between each iteration of the formula flowcode simulated movement
IR Sensor Iterations
Number of times to repeat the IR sensor tests and therefore how far the simulated IR sensors can sense.
IR Sensor Resolution
The amount of distance to travel for each iteration of the IR sensor
Collision Method
Sets whether the sensors on the formula flowcode interact with everything on the panel or just a specific group.
Simulations
