| Author
Matrix
| Version
1.2
| Category
LED Multicolour RGB (5mm, PCB) component
A simulatable RGB LED in a standard 5mm through-hole PCB mount package. Three port pins each output a simple PWM signal - one for each of the primary colours. The colors can then be mixed in any proportions to allow the desired color to be produced.
BASICIO
Red
| Pin that the red LED is connected to.
Green
| Pin that the green LED is connected to.
Blue
| Pin tha the Blue pin is connected to.
Polarity
| Active High: Use for common cathode LEDs - Pin true = LED On. Active Low: Use for common anode LEDs - Pin false = LED On.
Color bit size
| Color bit depth. Sets the resolution of the virtual PWM signals driving the LEDs. Lower values mean that the 'Tick' macro can be called less often, but reduced the number of colours that can be created.
Rollover value
| The number of unique colours each R/G/B channel can output. Range: 0 to (Rollover Value - 1).
Simulations
