Component: LED Array Template (LEDs)
Author | Matrix TSL |
Version | 2.0 |
Category | LEDs |
LED Array Template component
Create an evenly spaced array of LED indicators. Each will be connected to sequential pins of a given I/O port. Set target object to point at any standard LED component to change the style.
BASICIO
Example program which uses the point graph macro and loops to create a knight rider effect using the LED array.
Example program which reads an analogue value from an analogue input voltage and displays the reading in Binary on the LED array.
LEDs can be wired either active high or active low. The LED Array components have a property allowing you to configure which LED type your using.
LED Resistor Calculator Tool
BarGraph |
Turns on the first N elements of the array - for generating bar graph metes etc. | |
Length |
How many items to light up. | |
Return |
LEDOn |
Turn on the selected LED. | |
Index |
Index of the LED to turn on. | |
Return |
AllOn |
Turns on all elements | |
Return |
LEDOff |
Turn off the selected led. | |
Index |
Return |
PointGraph |
Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range. | |
Index |
The LED to show. | |
Return |
GetHandle |
Retrieves the object handle of the indexed clone. Returns zero for out of range indexes. | |
Index |
Return |
WriteValue |
Write a number which is presented on the LEDs in binary. | |
Value |
Provide a value to be written to the LEDs in binary | |
Return |
AllOff |
Turns off all elements | |
Return |
