Component: API (ESP32) (API Slave Devices)
Revision as of 11:10, 28 March 2022 by BenR (talk | contribs) (→Pin Mapping)
Version 2.0
Category API Slave Devices
API (ESP32) component
Connects to an ESP32 device running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
FREE
The App Developer (ESP32) component allows an ESP32 board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the ESP32 hardware the board must first be pre-programmed with dedicated firmware.
The firmware source project can be downloaded from here.
You will need to set your WIFI SSID and Password near the top of Main to allow the ESP module to connect to your network.
ESP32 App Developer Firmware
The IP Address to the ESP32 hardware is selected via the SCADA_ESP32 component IP Address property.
When building the component into a App Developer project remember to expose the IP Address property to allow the end user to select the address for the hardware.
  • fixed statistics showing IO / ADC inputs / PWM
  • scrolling log showing all commands and returns
Pin Mapping
Please note pins 34, 35, 36, 39 are only capable of digital inputs and cannot be used as digital outputs.
App Developer Slave Digital Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 21 22 23 25 26 27 32 33 34 35 36 39
Device Port Pin A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 A16 A17 A18 A19 A21 A22 A23 A25 A26 A27 B0 B1 B2 B3 B4 B7
GPIO Number 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 21 22 23 25 26 27 32 33 34 35 36 39
Please note not all analogue input pins are available as peripheral ADC2 is not accesible when WIFI/Bluetooth is active. Only the pins shown are available.
App Developer Slave Analogue Pin 0 3 4 5 6 7
Device Port Pin B4 B7 B0 B1 B2 B3
GPIO Number 36 39 32 33 34 35
Please note that PWM channels are tied in pairs and so channel 0 and 1 use the same internal timer peripheral. They will always run at the same frequency and when enabling channel 1 channel 0 duty will be reset to 0% and visa versa.
App Developer Slave Peripheral Pin I2C 0 SDA I2C 0 SCL I2C 1 SDA I2C 1 SCL SPI 0 MOSI SPI 0 MISO SPI 0 SCK SPI 1 MOSI SPI 1 MISO SPI 1 SCK UART 0 RX UART 0 TX UART 1 RX UART 1 TX PWM 0 PWM 1 PWM 2 PWM 3 PWM 4 PWM 5 PWM 6 PWM 7 PWM 8 PWM 9 PWM 10 PWM 11 OneWire
Device Port Pin A13 A12 A15 A14 A9 A10 A11 A6 A7 A8 A26 A25 B0 B1 A0 A2 A4 A5 A12 A13 A14 A15 A16 A17 A18 A19 A21
GPIO Number 13 12 15 14 9 10 11 6 7 8 26 25 32 33 0 2 4 5 12 13 14 15 16 17 18 19 21
PortA = GPIO pins 0 - 31 : A0 = GPIO 0
PortB = GPIO pins 32 - 39 : B0 = GPIO 32
I2CInitialise
Initialise the I2C module ready for communications
- BYTE Channel
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- BYTE Samples
8-bit samples returned from the function
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
OneWireBusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
- BYTE Channel
- BOOL Return
IOGetInputPin
- BYTE Pin
Range: 0-29
- BOOL Return
UARTBaud
- BYTE Channel
- BYTE Rate
OneWireInitialise
Initialise the OneWire module ready for communications
- BYTE Channel
OneWireMatchROM
Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
- BYTE Channel
- BYTE FamilyCode
- BYTE SerialNumber
ADCSample8
- BYTE ADCChannel
Range: 0, 3-7
I2CTransReceive
- BYTE Channel
- BYTE Data
Data variable to receive into
- UINT Count
Number of bytes to receive
UARTInitialise
- BYTE Channel
UARTCheckRX
- BYTE Channel
ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
- BYTE ChargeTime
Default 10
OneWireTransmitByte
Transmit a byte to the one wire bus a bit at a time
- BYTE Channel
- BYTE Data
I2CRestart
- BYTE Channel
PWMDisable
Disable a PWM output
- BYTE Channel
Range: 0-11
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
- BOOL Last
OneWireGetIDByte
Returns a single byte of the 64-Bit lasered ROM code, 255 on error
- BYTE Channel
- BYTE Device
Device ID - Range: 0 - NumDevices - 1
- BYTE ByteIndex
Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
PWMSetFrequency
Sets PWM frequency in Hz
- BYTE Channel
Range: 0 - 11
- LONG Frequency
Frequency (Hz)
I2CStop
- BYTE Channel
ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
- BYTE RefType
0=AREF, 1=VCC, 3=Internal 1.1V
OneWireSkipROM
Performs a bus reset and the sends the SkipROM command byte
- BYTE Channel
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
PWMSetDuty
- BYTE Channel
Range: 0-11
- BYTE Duty
ADCSample10
Reads the voltage present on an Analog pin as an 12-bit value range 0-4095
- BYTE ADCChannel
Range: 0, 3-7
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
IOSetOutputPin
- BYTE Pin
Range: 0-29
- BOOL State
Range: 0-1
UARTReceive
- BYTE Channel
ADCSampleAverage10
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
- BYTE Channel
SPIInitialise
- BYTE Channel
OneWireReceiveByte
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
- BOOL Return
UARTSend
- BYTE Channel
- BYTE Data
OneWireGetDeviceCount
- BYTE Channel
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-11
ADCSampleArray10
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleAverage8
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
ESP IP Address
IP Address of the Raspbery Pi we want to control
ESP Port
Port number we want to communicate on. Default 1234
Network Interface
Some computers may have several network interfaces such as ethernet ports and wifi access. Select the correct network interface for the network you wish to connect to. Use the IP address to confirm you are connected to the right network.
IP Address
IP Address of the selected network interface.
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
OneWire
SERVO
Console Log
Create an automatic console log of the commands sent to the ESP
Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns ASCII mode allows serial data to be shown in raw text form, other commands are shown as in the Command Log mode
Simulations
