Component: ADC (CAL) (Misc)
Revision as of 17:44, 9 November 2022 by Wiki bot (talk | contribs)
Version 2.0
Category Misc
ADC component
CAL - Code Abstraction Layer A low level implementation giving direct access to the analogue to digital converter peripheral.
Please click here for the component source code: FC_Comp_Source_ADC.fcfx
GetValue
Gets the Name property value
- STRING Name
The name of the property
- STRING Return
Disable
Disables the current ADC channel Call this once sampling is complete
Enable
Enables sampling of the ADC channel This is called every time a new ADC channel needs configuring to ADC mode [u]Only one ADC channel may be enabled at any time[/u] When sampling is complete, call Disable() to restore the pin
- BYTE Channel
A value >= 0 specifying the ADC channel
- BYTE Conv_Speed
Chip-specific rate of change read from the FCD <ADC.ConfSpeed>
- BYTE Vref
0 to disable Vref mode, else 1
- BYTE T_Charge
Aquisition time to wait in micro seconds
Sample
Blocking call to read a sample on the currently enabled channel
- BYTE Sample_Mode
True to enable full-width sample (10 or 12 bits), else false for 8 bit
SetValue
Sets the Value for the named property
- STRING Name
Name of property to update
- STRING Value
The new value for the property
GetList
- STRING Name
- STRING Return
Peripheral
Channel ADC Pin
ADC Channel number
Vref Option
selects the reference voltage option
Vref+ (x10mV)
sets the value of the reference voltage (used for conversion calculations)
Acq Time
ADC Aquisition time
Use FRC clock
Uses the internal fixed RC clock to perform ADC conversions. In most cases it is better to switch this off and use the conversion speed to ensure sampling is consistent.
Conv Speed
Conversion speed option
Type
Bits
Custom Pins
Has DMA
Use DMA
DMA Trigger
Has Scanning
Use Scanning
