Component: DMA (CAL) (Misc)
Revision as of 17:45, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Misc
DMA (CAL) component
CAL - Code Abstraction Layer A low level implementation giving direct access to DMA routines.
Please click here for the component source code: FC_Comp_Source_DMA.fcfx
WriteBuffer32
- ULONG Data
Disable
Disables the DMA channel.
ReadBuffer16
- UINT Data
ReadBuffer8
- BYTE Data
Enable
Initialise the DMA channel ready to process data to or from a peripheral. The user must enable the corresponding DMA interrupt after initialising the channel.
WriteBuffer16
- UINT Data
WriteBuffer8
- BYTE Data
ReadBuffer32
- ULONG Data
Enabled
Enables or Disables the DMA component from generating code.
DMA Peripheral Channel Each utilised DMA enabled component should use a unique channel number
Ping Pong
Controls the ping pong mode. True - Ping pong enabled, DMA memory double buffered to allow for seamless data sampling False - Ping pong disabled, DMA memory single buffered
Mode
DMA Type
Peripheral
Size
