Component: Display Manager (Graphical Library)
Revision as of 17:46, 9 November 2022 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Graphical Library
Display Manager component
Please click here for the component source code: FC_Comp_Source_DisplayManager.fcfx
MoveObject
Moves an existing object to absolute coordinates on the screen.
- UINT ObjectID
- UINT X
- UINT Y
ShiftObject
Shifts an existing object coordinates on the screen relative to the previous coordinates.
- UINT ObjectID
- INT X
- INT Y
DrawObject
Draws a single object onto the display without clearing the display. Doesn't draw a textfield component, this is done using the SetObjectText macro.
- UINT ObjectID
ScaleObject
Changes the width and height of the selected Object
- UINT ObjectID
- UINT Width
- UINT Height
RedrawAll
Clears the display and redraws all the content from the display manager objects. Doesn't draw textfield components, this is done using the SetObjectText macro.
SetObjectText
Assigns text to a single line text object and draws directly to the display. Blanks the selected area first to ensure nothing from previous text is left behind.
- UINT ObjectID
- STRING Text
- BYTE Font
CreateObject
Define an object on the graphical LCD. Returns the Object ID.
- UINT ObjectType
- UINT X
- UINT Y
- UINT Width
- UINT Height
GLCD Component
Selects the GLCD component to display all the objects
Max Objects
The total number of objects allowed on the screen. Sets the size of the RAM buffers used to track the various screen elements.
