Component: EtherCAT Slave (EasyCAT) (Comms: IoT/Cloud)
Revision as of 17:46, 9 November 2022 by Wiki bot (talk | contribs)
Category Comms: IoT/Cloud
EtherCAT Slave (EasyCAT) component
Provides support for the EtherCAT Slave industrial protocol using an EasyCAT Arduino shield. The shield can be driven from a Flowcode compatible Arduino type board or can be driven using an Arduino using the SCADA Slave firmware to drive EtherCAT from the Flowcode simulation runtime. Compatible with the EasyCAT Easy Configurator tool.
Please click here for the component source code: FC_Comp_Source_EasyCat.fcfx
SetInt
Write a 16-bit value to the In receive buffer
- BYTE Index
Data Index
- UINT Data
MainTask
Must be called as part of the application main program loop.
SetLong
Write a 32-bit value to the In receive buffer
- BYTE Index
Data Index
- ULONG Data
GetFloat
Read a 32-bit floating point value from the Out receive buffer
- BYTE Index
Data Index
- FLOAT Return
GetLong
Read a 32-bit value from the Out receive buffer
- BYTE Index
Data Index
- ULONG Return
GetInt
Read a 16-bit value from the Out receive buffer
- BYTE Index
Data Index
SetByte
Write an 8-bit value to the In receive buffer
- BYTE Index
Data Index
- BYTE Data
GetByte
Read a 8-bit value from the Out receive buffer
- BYTE Index
Data Index
SetFloat
Write a 32-bit floating point value to the In receive buffer
- BYTE Index
Data Index
- FLOAT Data
Starts up the SPI connection to the EasyCAT board and configures the board. Returns 1 for a sucessful initialise.
- BOOL Return
Synchronisation Mode
ASYNC = free running i.e. no synchronization between master and slave (default) DC_SYNC = interrupt is generated from the distributed clock unit SM_SYNC = interrupt is generated from the syncronisation manager
Header File
Used to load a header file from Easy CAT Configurator tool to describe the units inputs and outputs
Data Rx
Total Byte Num Out
Total number of bytes to come out from the EtherCAT master
Data Tx
Total Byte Num In
Total bytes to come in from the EtherCAT master
SPI Properties
SPI Channel selector
MOSI
MISO
CLK
CS / SS
Prescale
Prescale option selector
Simulation Comms
