| Author
Matrix TSL
| Version
1.1
| Category
Alphanumeric
LCD (Generic, 16x2) component
LCD based on the unit used in the Matrix EB005 E-block
Please click here for the component source code: FC_Comp_Source_LCD_16X2.fcfx
Example of a typical LCD pinout.
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
A simple example that shows how to use some common functions.
LCD Example
Clear
| Clears the entire contents of the display.
PrintString
| Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro
- STRING
Text
| Enter the text or variable to print to the LCD
PrintAscii
| Takes the ascii value for a character and prints the character
- BYTE
character
| Holds an ascii value.
| Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT
Number
| Enter the number or variable to print to the LCD
RAMWrite
| Modifies the internal memory of the LCD to allow for up to 8 customised characters to be created and stored in the device memory
- BYTE
Index
| Values 0 to 7
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
ClearLine
| Clears a single line on the display and then moves the cursor to the start of the line to allow you to start populating the line with data.
- BYTE
Line
| The line to clear, zero being the first (top) line of the display
Cursor
| Moves the cursor on the LCD Display
- BYTE
x
| Set the cursor position in the X plane, 0 is the left most cell
- BYTE
y
| Set the cursor position in the Y plane, 0 is the top most cell
Command
| Use this method/macro to send a specific command to the LCD. Refer to the Matrix Multimedia EB006 datasheet for a list of supported instructions. For Non-Matrix LCD's refer to the manufacturers datasheet.
- BYTE
instruction
| Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
| Will allow you to print a number up to 32-bits with signed or unsigned formatting. Signed = -2147483648 to 2147483647 Unsigned = 0 to 4294967295
- ULONG
Number
- BOOL
Format
| 0=Signed, 1=Unsigned
ScrollDisplay
| Scrolls the display left or right by a number of given positions.
- BYTE
Position
| Holds the number of positions to shift the display
- BYTE
Direction
| 0 = left, 1 = right
RawSend
| Sends data to the LCD display
- BYTE
data
| The data byte to send to the LCD
- BOOL
type
| A boolean to indicate command type: true to write data, false to write a command
PrintFloat
| Print a Float number rounded up to a specified amount of decimal places.
- FLOAT
Number
- BYTE
DecimalPlaces
| Enter how many decimal places to round up to (1 - 6)
RemapCharacter
| Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE
RemapIdx
| Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE
SearchCharacter
| Character to look for a replace
- BYTE
ReplacementCharacter
| New character value to use in place of the search character.
Start
| Startup routine required by the hardware device. Automatically clears the display after initialising.
Data 0 (11)
Data 1 (12)
Data 2 (13)
Data 3 (14)
Register Select (4)
Enable (6)
Component Label
Component Label Scale
Text Colour
| Colour of the font characters drawn on the display
Text Background
| Colour surrounding the font characters drawn on the display
Display Background
| Colour of the background of the display
