Component: LIN Slave (Comms: Interface)
Revision as of 17:49, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.2 |- | width="20%" style="color:gray...")
Version 1.2
Category Comms: Interface
LIN Slave component
Low level routines for controlling the LIN bus (1.3 / 2.0) slave interface.
Please click here for the component source code: FC_Comp_Source_LinSlaveV2.fcfx
PowerDown
Puts the bus into the Powered Down state driving the CS pin low.
ListenForMessages
Listens for messages with Timeout and returns the state. Returns 255 for timeout, 254 for CRC error and 0 for none matching ID received. Returns 1-8 for a valid ID received.
- BYTE Timeout
timeout in milliseconds to wait for incoming message, 255=Wait Forever
ReadDataCount
Return the data count size for Message
- BYTE Message
Range: 1 - Num Messages
ReadData
Get the Message data automatically received from a specific message as part of the ListenForMessages macro.
- BYTE Message
Message index to be read. Range: 1 - Num Messages
- BYTE Data
SetData
Set the Message data to be automatically sent for a specific message as part of the ListenForMessages macro.
- BYTE Message
Message index to write. Range: 1 - Num Messages
- BYTE Data
WakeUp
Puts the bus into the Wake state driving the CS pin high.
Initialises the device ready for communications from the master. Puts the bus into the Wake state driving the CS pin high.
Bus Options
Baud Options
Messages
Number of messages the firmware is designed to listen for
Checksum Type
TX
RX
CS pin
LIN bus chip select pin
MESSAGE1
ID
Message identifier to listen for
BYTES
Number of bytes to expent in the packet
TX_RX
Data direction for packet
Console Format
Controls if the data is shown as a log with time and date stamps or just as raw data
Console Columns
Data Source
Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
