Component: SCADA (Dummy) (SCADA Slaves)
Revision as of 17:49, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category SCADA Slaves
SCADA (Dummy) component
Dummy SCADA Slave component to enable injector referencing. Supports: Digital IO / ADC / I2C / SPI / PWM See Flowcode Help Wiki for firmware.
Please click here for the component source code: FC_Comp_Source_OLD_API_Slave_Dummy.fcfx
I2CInitialise
IOGetInputPin
- BYTE Pin
Range: 0-13
- BOOL Return
I2CRestart
I2CStart
SPITransfer
- BYTE DataOut
I2CReceive
- BOOL Last
I2CStop
SPIPrescaler
- BYTE Prescaler
Range: 0-2
IOSetOutputPin
- BYTE Pin
Range: 0-13
- BOOL State
Range: 0-1
SPIInitialise
I2CSend
- BYTE DataOut
- BOOL Return
