Component: GLCD (ILI9341) (Graphical Color)
Revision as of 17:52, 9 November 2022 by Wiki bot (talk | contribs)
Version 2.0
Category Graphical Color
GLCD (ILI9341) component
Graphical display component designed to work with the ILI9341 controller IC Based on the ILI9341 16-bit colour graphical controller IC. Supports Serial, 8-bit and 16-bit interface modes.
Please click here for the component source code: FC_Comp_Source_glcd_ILI9341.fcfx
ReadFontWidth
- BYTE Font
- BYTE Character
BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
LCD_Write_Reg
- BYTE data
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
LCD_Write_Data8
- BYTE data
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
FastPlot
SetDisplayOrientation
- BYTE Orientation
BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BPlot
- UINT X1
- UINT Y1
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
Flip X
Flips the horizontal display axis in hardware.
Flip Y
Flips the vertical display axis in hardware.
Colour
Monochrome
Foreground Color
Background Color
Invert Colour
Some display hardware may require colours to be inverted
Swap Red / Blue
Allows Red and Blue colour channels to be swapped to match the way the display has been wired to the controller IC.
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Connection Type
Data Out (MOSI)
Data pin connection
Clock (SCL)
Clock pin connection
Toggle CS
Allows the CS pin to be toggled by the component when communicating with the display. No - Allows for better performace, the display is always enabled Yes - Allows for the display pins to be multiplexed with other functionality without the risk of display corruption
Chip Select (CS)
Chip select pin connection
Reg Select (D/C)
Reset
Reset pin connection
Use Backlight Pin
LED
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Display Method
