| Author
Matrix Ltd
| Version
2.0
| Category
Graphical Color
GLCD (ILI9488) component
Graphical display component designed to work with the ILI9488 controller IC Based on the ILI9488 16-bit colour graphical controller IC. Supports Serial, 8-bit and 16-bit interface modes.
Please click here for the component source code: FC_Comp_Source_glcd_ILI9488.fcfx
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
BacklightOn
| Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
LCD_Write_Reg
- BYTE
data
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
LCD_Write_Data8
- BYTE
data
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
FastPlot
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0.
SetDisplayOrientation
- BYTE
Orientation
BacklightOff
| Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BPlot
- UINT
X1
- UINT
Y1
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
- BYTE
Red
| 0 - 255 where 0 = no red and 255 = maximum red
- BYTE
Green
| 0 - 255 where 0 = no green and 255 = maximum green
- BYTE
Blue
| 0 - 255 where 0 = no blue and 255 = maximum blue
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Width
Pixel Height
Flip X
| Flips the horizontal display axis in hardware.
Flip Y
| Flips the vertical display axis in hardware.
Colour
Monochrome
Foreground Color
Background Color
Invert Colour
| No: A set output will light the corresponding LED Yes: A clear output will light the corresponding LED
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Connection Type
Write (WR)
Read (RD)
Toggle CS
| Allows the CS pin to be toggled by the component when communicating with the display. No - Allows for better performace, the display is always enabled Yes - Allows for the display pins to be multiplexed with other functionality without the risk of display corruption
Chip Select (CS)
| Chip select pin connection
Reg Select (D/C)
| Instruction / Command pin connection
Use Ports
| Allows the 8-bit or 16-bit data to be controlled using 8-bit ports. Yes - Ports will be used allowing for better data rates No - individual I/O pins will be used allowing for better flexibility
Data0
Data1
Data2
Data3
Data4
Data5
Data6
Data7
Reset
| Reset pin connection
Use Backlight Pin
LED
| LED backlight strobe pin connection
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Display Method
