Component: GLCD (SSD1322) Parallel (Graphical Monochrome)
Revision as of 17:53, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.3
Category Graphical Monochrome
GLCD (SSD1322) Parallel component
Graphical display component designed to work with the SSD1322 type monochrome displays. Compatible with 6800 and 8080 type 8-bit parallel displays.
Please click here for the component source code: FC_Comp_Source_glcd_SSD1322.fcfx
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
SetDisplayOrientation
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
SetShadeIntensity
Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
- BYTE Shade
Range: 1-15 / 1=Dim / 15 = Bright
ClearDisplay
SetBackgroundColour
- BYTE Pixel_Colour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE Pixel_Colour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Colour
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Display Settings
Enable Delay
Time in micro seconds to wait before and after toggling the enable pin.
Interface Type
Sets the display interface type, this wil lhave to match the gLCD hardware setting.
CS
Chip select to address the first controller IC
R/W / Write
6800 - Read / Write Selection Pin 8080 - Write Enable Pin
Enable / Read
6800 - Enable Pin 8080 - Read Enable Pin
Data/Command
Data / Command selection pin
Reset
Display reset pin
Use Port
Controls if the data is sent via an 8-bit port, significantly speeding up writes to the display.
Data Port
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Component Label
Component Label Scale
Display Method
