Component: LED MultiColour Bi (5mm, PCB) (LED)
Revision as of 17:53, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.1
Category LED
LED MultiColour Bi (5mm, PCB) component
An industry standard 5mm diameter bi-colour LED. Any color may be chosen, and the leads trimmed to length.
Please click here for the component source code: FC_Comp_Source_led_5mm_bicolour.fcfx
A Bi Colour LED should be connected between two microcontroller I/O pins as shown below.
LED Resistor Calculator Tool
Fc9-comp-macro.png LEDOff
Switches off the LED
Fc9-comp-macro.png LEDSetState
Controls the state of the LED. 0=Off 1=LED Colour 1 2=LED Colour 2
Fc9-u8-icon.png - BYTE State
0=Off, 1=Pin1 High & Pin2 Low, 2=Pin1 Low & Pin2 High
Fc9-comp-macro.png LEDOneOn
Switches on LED one
Fc9-comp-macro.png LEDTwoOn
Switches on LED two
Fc9-type-5-icon.png Pin
LED Pin 1
Fc9-type-5-icon.png Pin2
LED Pin 2
Fc9-conn-icon.png Simulation
Fc9-type-1-icon.png Color
The color of the LED when pin1 is turned on and pin2 is turned off.
Fc9-type-1-icon.png Color2
The color of the LED when pin1 is turned off and pin2 is turned on.
Fc9-type-15-icon.png Trim Leads
Trim the length of the two leads. Length cannot be less than 3.0, or greater than the length as supplied.
Fc9-conn-icon.png Label
Color of the labels text.
Fc9-type-15-icon.png Scale
Sets the basic size (text height) of the labels.
Fc9-type-7-icon.png Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
