Component: Switch (Rocker) ()
Revision as of 17:54, 9 November 2022 by Wiki bot (talk | contribs)
Category
Switch (Rocker) component
Rocker switch with indicator lamp and properties for changing the colours of each part.
Please click here for the component source code: FC_Comp_Source_sw_rocker_neon.fcfx
Colours
LED
Color of the indicator lamp built into the switch. Property sets the 'on' color - 'off' color will be a much darker shade of the same hue.
Rocker
Color for the moving part of the switch.
Bezel
Color of the switch bezel (surround)
Connection
Chip pin to which this switch is connected.
Polarity
Sets whether activating the switch tales the chip pin high or low.
Debounce (ms)
Time in milliseconds allowed for the chip pin to settle after a change of switch state. NB) Debouncing is only used when reading the switch state with the component macros. Chip pins are NOT debounced!
Operation
Latching = Click to turn on, click again to turn off. Momentary = Click to turn on, release to turn off.
