Global Settings
The Global Settings allow the user to set display options for Flowcode. You can access these settings by pressing 'File' then 'Global Settings...' at the bottom.
The options are split into tabs (sections) which each contain different options to allow you to change different aspects of Flowcode.
These options configure the program itself, from changes to appearance, customization of the program to the ability to personalize the program to your preference.
Other options available also allow control over web access and proxy settings as well as the ability to override the default language to display a different language.
You also have the ability to add directories and locations to search for components and directories to be used in Flowcode, you can also change the default directory of the compiler output location, you can do all this and more from within the Global Settings.
- 1 Application Tab
- 1.1 Use dashboard as default panel
- 1.2 Disable system panel
- 1.3 Show popup on simulation end
- 1.4 Auto-edit new icons
- 1.5 Autosave periodically
- 1.6 Add icons comments to C code
- 1.7 Allow errors in flowcharts
- 1.8 Allow unconnected ports and pins
- 1.9 Create separate .c and .h files
- 1.10 Web Access
- 1.11 Show help in external browser
- 1.12 Show forums in external browser
- 1.13 Show forums in external browser
- 1.14 Graphics Engine
- 2 Flowchart Tab
- 3 Scheme Tab
- 4 Annotations Tab
- 5 Editor Tab
- 6 Locations Tab
Application Tab
Override Language
Allows the user to override the default Flowcode language settings and to display Flowcode in the specified language. Select the language from those available on the drop down list. Note: The relevant language packs need to be installed for Flowcode to enable that particular language.
When checked, components are added to the dashboard panel by default, instead of the system panel.
Disables the system panel completely, leaving the 2D panel to handle components and 2D graphics.
Displays a popup at the end of simulation which displays the duration of the simulation as well as other technical information.
Auto-edit new icons
Automatically opens the Icon Properties when adding a new icon.
Enables the autosave feature of Flowcode. This will create a backup file named the same as your project but with the .fcbx file suffix. You can set how often the autosave will work, the minimum setting is every 60 seconds.
Toggling this option will change whether icons include their associated C-code comments.
Allows you to edit icons without error messages, errors messages still occur when simulating and compiling the program.
Allows you to change component connection properties to unconnected, error messages still occur when simulating and compiling the program.
C code files are optionally saved as separate c/h files for incorporation into external projects
Web Access
Configures the settings to allow Flowcode to connect to the internet. Used for features like online activation and to drive the content in the start page and auto updates.
Opens wiki help pages in your default external browser
Opens the forums main page in your default external browser
===Check for core updates on launch
Checks for any new versions of Flowcode and shows
for a few seconds if any are found.
You will need to click on the Core update available text for the upgrade to start.
==Enable background checking for library updates. When you add a component that has a later version available a pop-up will show Component_update_available.png for a few seconds. You will need to click on the Updates Available text for the upgrade to start.
Graphics Engine
Configures how we display objects on the simulation panels. Software mode is the default setting as it is more reliable for all users at the cost of being fairly slow. Hardware mode obviously is dependent on your specific 3D acceleration hardware meaning it may potentially have problems, if it does work ok with your hardware then it should be faster then the software mode.
Flowchart Tab
Font name
Allows users to set the font used by Flowcode
Font size
Allows users to set the default font size used by Flowcode
Icon graphics style
This menu allows users to select a different graphics style for the entire project, selecting a graphics style will alter the look of the flowchart view mode.
Source graphics style
This menu allows users to select a different graphics style for the source view mode.
Indent loop flowlines
Allows the flowchart line to be indented when part of a loop to make it much more obvious what code is placed inside the braces of the loop icon.
Transparent background
Selecting this option will set all backgrounds to be fully transparent when saving any .png or .bmp files from flowcode, this will ignore any colors set as the background.
Bind icon toolbar to programming view
Changes whether the flowchart icons bind to individual flowchart windows or whether they are global throughout the program.
Scheme Tab
Scheme
This menu allows users to select a colour scheme for the flowchart icons. Users can also choose their own colour schemes and save them.
Background
Users can manually select the colour scheme, including foreground pattern, for the flowchart area. Users can also select the selection' and 'execution' colours.
Icon
Here users can manually change the colour of icons to suit their requirements.
Annotations Tab
Show description for icons
Controls whether the descriptions for icons are shown above the icon in the flowchart window.
Show text inside icons
Controls the text inside the flowchart icons allowing it to be displayed or hidden.
Show Annotations
Controls the bubble annotations next to the flowchart icons allowing them to be displayed or hidden.
Limit description size for all icons
Selecting this option will limit the size of the descriptions above the icons to a suitably sensible width.
Limit annotation size for all new icons
This option will limit the annotation size for any newly created icons, retaining any previously resized annotation.
Annotation style
This will set the global default annotation style for newly created icons. Icons can also have their annotation styles changed on an individual basis, selecting this option will not change existing icons annotation styles.
- Flowcode - This annotation style shows the Flowcode code behind the icon
- C code - This style will show C code behind the icon
- Comments - Setting this style will show any custom comments in the annotation.
Tooltip style
This will set the global tooltip style, the tooltip is shown when hovering over any icon in the main flowchart window. This is independent of the annotation style which can be changed on a per-icon basis, the tooltips are changed by this global setting only.
Annotation - By selecting this option the tooltip will recreate the same information as the annotation.
Flowcode - This tooltip style shows the Flowcode code behind the icon
Comments - Setting this style will show any custom comments in the tooltip.
Editor Tab
Locations Tab
Send compiler output to...
This option decides the default target directory to output to when compiling.
Create a backup file as
Allows a backup project file to be created based on the previous save of the file. If you need to go back then simply rename the file using Windows explorer and change the filetype from .001 to .fcfx.
Look for components in...
This option allows you to include additional directories for Flowcode to search when looking for components.
Clear component cache
Refreshes the current component cache based on the directories provided. Also performed when opening the Flowcode application and loading a project.
Look for dictionaries in...
This option allows you to include additional directories for Flowcode to search when looking for dictionaries to integrate into Flowcode.
