| Author
Matrix Ltd
| Version
1.3
| Category
Potentiometer (Slider) component
Analogue slider with plastic cap and 100mm travel. Cap and marker colour can be changed in component properties.
Note: The default Vref properties for AVR/Arduino is AREF.
If there is no voltage being applied to the AREF pin, then you must change Vref option from AREF to AVCC
Please click here for the component source code: FC_Comp_Source_pot_Slider.fcfx
Potentiometer Example
Tang Color
| Colour of the moving part of the slider.
Marker Color
| Colour of the marker line across the slider tang.
Body Color
| Specifies the color of the slider body
Retain Value
| If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
| Analogue input channel - which pin is the analogue input conected to?
Settings
VRef voltage
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage. VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ACD input to charge before starting the analogue sample.
Bit Depth
| Maximum number of digital bits the ADC can sample. 8 bit = ADC range 0 - 255 10 bit = ADC range 0 - 1023 12 bit = ADC range 0 - 4095
