Component: Display Manager (Graphical Library)
Author MatrixTSL
Category Graphical Library
Display Manager component
Please click here for the component source code: FC_Comp_Source_DisplayManager.fcfx
The component can create the follow objects.
Type_line - A simple straight line.
Type_Rectangle - A simple rectangular box.
Type_RectangeFilled - A filled rectangular box.
Type_Ellipse - A simple ellipse or circle.
Type_EllipseFilled - A filled ellipse or circle.
Type_TextBox - A text area allowing a line of text to be displayed.
The type can be entered by using the public constants. Begin with the Display Manager handle name followed by :: and the list of the public variables will be displayed.
For example... DisplayManager1::Type_TextBox
An example showing the creation of some text areas inside formatted shapes.
FC6 Icon.png Display Manager Example
Fc9-comp-macro.png MoveObject
Moves an existing object to absolute coordinates on the screen.
Fc9-u16-icon.png - UINT ObjectID
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png ShiftObject
Shifts an existing object coordinates on the screen relative to the previous coordinates.
Fc9-s16-icon.png - INT X
Fc9-s16-icon.png - INT Y
Fc9-comp-macro.png DrawObject
Draws a single object onto the display without clearing the display. Doesn't draw a textfield component, this is done using the SetObjectText macro.
Fc9-comp-macro.png ScaleObject
Changes the width and height of the selected Object
Fc9-u16-icon.png - UINT Width
Fc9-u16-icon.png - UINT Height
Fc9-comp-macro.png RedrawAll
Redraws all the content from the display manager objects. Doesn't draw textfield components, this is done using the SetObjectText macro.
Fc9-comp-macro.png SetObjectText
Assigns text to a single line text object and draws directly to the display. Blanks the selected area first to ensure nothing from previous text is left behind.
Fc9-u8-icon.png - BYTE Font
Fc9-comp-macro.png CreateObject
Define an object on the graphical LCD. Returns the Object ID.
Fc9-u16-icon.png - UINT ObjectType
0=TextBox, 1=Rect, 2=Line, 3=Ellipse, 4=FilledEllipse, 5=FilledRect
X Pixel Coordinate
Y Pixel Coordinate
Pixel Width or X Radius
Pixel Height or Y Radius
Fc9-type-17-icon.png GLCD Component
Selects the GLCD component to display all the objects
Fc9-type-21-icon.png Max Objects
The total number of objects allowed on the screen. Sets the size of the RAM buffers used to track the various screen elements.
