API Panel.Position.Morph
Revision as of 11:41, 16 January 2023 by Wiki bot (talk | contribs)
Morph
Blends positions from two sources to a destination
- HANDLE Dest
- HANDLE Start
The initial position at Step=0
- HANDLE End
The final position at Step=1
- FLOAT Step
A value from 0 to 1 for the position between Start and End
- BOOL CurveArcs
True to curve movement if rotation is applied, false for linear movement
- NONE Return
This call smoothly interpolates between two objects, storing the result in a third Dest position.
The Step may be any value and is not bounded by Flowcode, but typically lies within the range of 0 to 1. A value of 0 represents the position of Start and 1 represents End.
The Animate call performs this operation over a fixed time, selecting the Step from 0 to 1 appropriately then invoking this routine.
  • Add to a calculation icon:
    ::Panel.Position.Morph(dest, start, end, step, false)
