API Expand.PathName
| PathName | |
| Expands a string using the built-in pathname expansion variables | |
| Source | |
| The text to expand | |
This does not resolve a pathname, for this use File.AbsPath. What this will do is use the $(variable) syntax to expand the string using built-in variable names used in the compiler settings and other pathname fields in Flowcode.
The list of variables available in this expansion are:
| Variable | Meaning |
| appdir | The Flowcode applications directory |
| chip | The name of the target chip, eg 16F88 |
| family | The family of the target chip, eg 16F |
| platform | The platform of the target chip, eg PIC |
| chippath | The full name of the target chip, eg PIC.16F.16F88 |
| chipalt | The alternate-name of the target chip |
| cfga | The address of the base of the config, as specified in the FCD file |
| cfgb | The number of bytes of the config specified in the FCD file |
| cfgen | Whether the user has selected to write config to the chip |
| cfgN | Starting with cfg0, the slot values specified in the config |
| target | The source or target file leafname, without an extension, eg my_project |
| srcdir | The directory the my-project.fcf file is located in |
| outdir | The directory output and intermediate files are sent to |
- Add to a calculation icon:
result = ::Expand.PathName("source")
