API Sound
Revision as of 12:21, 14 May 2013 by JonnyW (talk | contribs) (XML import API changes)
<sidebar>API contents</sidebar> Audio streaming interface
Functions provided for this class
Play Plays a formatted file sound, returns true if the sound played OK
LoadWav Loads a wave file into memory, providing the values needed to play it
Create Creates a sound object that data can be played through
SetVolume Sets the volume of playbacks for this sound
GetVolume Gets the volume of playbacks for this sound in the range 0 to 1
GetBits Gets the number of bits per sample for the sound
GetRate Gets the current sample rate for the sound
SetRate Sets the current sample rate for the sound - this will stop the playing sound
Queue Queues a sound for playing
QueueEx Queues a sound for playing, with the format provided
Flush Stops all playing and queued sounds
GetPending Gets the number of sample blocks queued or playing for the sound
Constants provided for this class
Type Name Value Description
LONG Fmt_Signed8 4 Source data is in the range -128 to 127
LONG Fmt_Unsigned8 5 Source data is in the range 0 to 255
LONG Fmt_Signed16 8 Source data is in the range -32768 to 32767
LONG Fmt_Unsigned16 9 Source data is in the range 0 to 65535
LONG Fmt_Signed32 16 Source data is a signed 32-bit value
LONG Fmt_Unsigned32 17 Source data is an unsigned 32-bit value
LONG Fmt_Float32 18 Source data is a 32-bit float from 0 to 1
LONG Fmt_Float64 34 Source data is a 64-bit float from 0 to 1
LONG Fmt_Mono 256 Set this flag to set a single source element per sample
LONG Fmt_Stereo 512 Set this flag to two source elements per sample
See also
