Component: API SPI Dummy (API Slave Devices)
Revision as of 14:39, 16 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category API Slave Devices
API SPI Dummy component
Connects to an Arduino Mega running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here for the component source code: FC_Comp_Source_API_SPI_Dummy.fcfx
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
SPITransfer
- BYTE Channel
- BYTE DataOut
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
IOSetOutputPin
- BYTE Pin
Range: 0-53
- BOOL State
Range: 0-1
SPIInitialise
- BYTE Channel
