Component: Accelerometer 3-Axis (LIS3DHTR) (LIS3DHTR) (Movement Orientation)
Revision as of 14:39, 16 January 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.6 |- | width="20%" style="color:gray...")
Version 1.6
Category Movement Orientation
Accelerometer 3-Axis (LIS3DHTR) component
LIS3DHTR 3-Axis Accelerometer sensor.
Please click here for the component source code: FC_Comp_Source_Accelerometer_LIS3DHTR.fcfx
Fc9-comp-macro.png Read_Register
Reads a value from a register on the accelerometer.
Fc9-u8-icon.png - BYTE Reg
Fc9-comp-macro.png SimReset1G
Fc9-comp-macro.png Write_Register
Writes a data value to a specific register on the accelerometer
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png SimSetAccelerometer
Allows the XYZ slider values to be set via the simulation
Fc9-s16-icon.png - INT X
Fc9-s16-icon.png - INT Y
Fc9-s16-icon.png - INT Z
Fc9-comp-macro.png CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
Fc9-u8-icon.png - BYTE Axis
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
Fc9-comp-macro.png Initialise
Sets up up the communication bus and initialises the accelerometer module. Returns 1 for success and 0 for fail.
Fc9-type-16-icon.png Accel Data Rate
Fc9-type-16-icon.png Accel Scale
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulation
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the I2C CAL component - Injector etc
