Component: API (BL0032) (API Slave Devices)
Revision as of 14:39, 16 January 2023 by Wiki bot (talk | contribs)
Version 2.1
Category API Slave Devices
API (BL0032) component
Connects to an BL0032 dsPIC running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here for the component source code: FC_Comp_Source_BL0032_API_Comp.fcfx
The App Developer (BL0032 dsPIC E-Block) component allows an BL0032 dsPIC E-block board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Arduino Uno hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
BL0032 dsPIC App Developer Firmware
The USB should be connected to the Target port on the E-block board to allow Flowcode to communicate with the Target microcontroller.
The COM port to the E-block hardware is selected via the SCADA_BL0032 component COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
  • fixed statistics showing IO / ADC inputs / PWM
  • scrolling log showing all commands and returns
Pin Mapping
Here is a table showing how the slave digital pins are mapped on the device.
App Developer Slave Digital Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
Device Port Pin B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 B10 B11 B12 B13 B14 B15 D0 D1 D2 D3 D4 D5 D6 D7 E0 E1 E2 E3 E4 E5 E6 E7 F0 F1 F3 F4 F5 C13 C14 D8 D9 D10 D11 G6 G7 G8 G9
Here is a table showing how the slave analogue pins are mapped on the device.
App Developer Slave Analogue Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
Device Port Pin B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 B10 B11 B12 B13 B14 B15 E0 E1 E2 E3 E4 E5 E6 E7
Here is a table showing how the slave peripheral pins are mapped on the device.
App Developer Slave Peripheral Pin I2C 0 SDA I2C 0 SCL I2C 1 SDA I2C 1 SCL SPI 0 MOSI SPI 0 MISO SPI 0 SCK SPI 1 MOSI SPI 1 MISO SPI 1 SCK SPI 2 MOSI SPI 2 MISO SPI 2 SCK SPI 3 MOSI SPI 3 MISO SPI 3 SCK UART 0 RX UART 0 TX UART 1 RX UART 1 TX UART 2 RX UART 2 TX UART 3 RX UART 3 TX
Device Port Pin D9 D10 F4 F5 D3 D4 D5 G8 G7 G6 E0 E1 E2 F3 F4 F5 F0 F1 D0 D1 G9 G8 G7 G6
App Developer Slave Peripheral Pin PWM 0 PWM 1 PWM 2 PWM 3 PWM 4 PWM 5 PWM 6 PWM 7 PWM 8 PWM 9 PWM 10 PWM 11 PWM 12 PWM 13 PWM 14 PWM 15
Device Port Pin D0 D1 D2 D3 D4 D5 D6 D7 F0 F1 F3 F4 F5 E0 E2 E4
I2CInitialise
- BYTE Channel
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- BYTE Samples
8-bit samples returned from the function
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
IOGetInputPin
- BYTE Pin
Range: 0-47 ... Pin 34 unimplemented
- BOOL Return
UARTBaud
- BYTE Channel
- BYTE Rate
ADCSample8
- BYTE ADCChannel
Range: 0-31 ... Channels 16-23 unimplemented
I2CTransReceive
- BYTE Channel
- BYTE Data
Data variable to receive into
- UINT Count
Number of bytes to receive
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
RegisterWrite
Writes to one of the registers on-board the device
- UINT RegisterAddress
The address of the register
- UINT Data
The data value to assign to the register
ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
- BYTE ChargeTime
Default 10
RegisterRead
Read one of the registers on-board the device
I2CRestart
- BYTE Channel
PWMDisable
Disable a PWM output
- BYTE Channel
Range: 0-15
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
- BOOL Last
I2CStop
- BYTE Channel
ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
- BYTE RefType
0=AREF, 1=VCC, 3=Internal 1.1V
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
ADCSample12
Reads the voltage present on an Analog pin as an 12-bit value range 0-4095
- BYTE ADCChannel
PWMSetDuty
- BYTE Channel
Range: 0-15
- BYTE Duty
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
IOSetOutputPin
- BYTE Pin
- BOOL State
Range: 0-1
UARTReceive
- BYTE Channel
ADCSampleAverage10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
SPIInitialise
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
- BOOL Return
UARTSend
- BYTE Channel
- BYTE Data
PWMSetPrescaler
- BYTE Channel
Range: 0-15
- BYTE Prescaler
- BYTE Period
Default 255
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-15
ADCSampleArray10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleAverage8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
Connection
Auto Detect Port
Allows the component to auto detect the interface board COM port. Requires the latest Flowcode serial comms DLL to function correctly.
COM Port
Lists all the current available COM port hardware on your PC.
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
SERVO
Console
Console Log
Create an automatic console log of the commands sent to the Arduino
Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns
