Component: Colour Sensor (TCS3200) (Light)
Version | 1.1 |
Category | Light |
Colour Sensor component
This board provides the ability to detect colours using the TCS3200 sensor. It will return RGB and W values, dependent on the colour of the object under test.
Please click here for the component source code: FC_Comp_Source_Colour_TCS3200.fcfx
SetConfig | |
Sends the config data byte to the sensor using clock and data pins | |
- BYTE | Data |
- VOID | Return |
SetLEDOn | |
Turn on the White LEDs | |
- VOID | Return |
SetFrequencyRange | |
Dynamically change the sensor output frequency range to a new setting | |
- BYTE | Freq |
Percentage range (2,20,100) | |
- VOID | Return |
GetFrequency | |
Samples and returns the sensor output frequency (Hz) | |
- UINT | Return |
SetFilter | |
Dynamically change the sensor filter to RGB or W. Red = 0 Green = 1 Blue = 2 White = 3 | |
- BYTE | FilterColour |
Filter Colour; Red = 0, Green = 1, Blue = 2 and White = 3 | |
- VOID | Return |
SetLEDOff | |
Turn off the White LEDs | |
- VOID | Return |
Initialise | |
Initialise the sensor configuration as set by the component properties | |
- VOID | Return |
