Component: Coupling (Mechatronics)
Revision as of 14:39, 16 January 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Mechatronics
Coupling component
A simple component to couple together two rotating shafts. An essential component when working with motors, gearboxes, encoders and other rotational systems.
Please click here for the component source code: FC_Comp_Source_Coupling.fcfx
Rotate
Simulation macro called behind the scenes by motor components when rotating.
- FLOAT Angle
Input
Input connection for example a motor or other active component or primitive.
Output
Output connection for example a primitive or a component such as a linear slide or gearbox.
Input Offset
Distance along the shaft from the center of the input object to the center of the coupling.
Output Offset
Distance along the shaft from the center of the coupling to the center of the output object.
Output Translation X
Distance along the X axis from the center of the coupling to the center of the output object.
Output Translation Y
Distance along the Y axis from the center of the coupling to the center of the output object.
Panel Properties
Width
Height
Depth
