Component: DAC (MCP47x6) (MCP47x6) (Analog Output)
Revision as of 14:39, 16 January 2023 by Wiki bot (talk | contribs)
Category Analog Output
DAC (MCP47x6) component
Component to drive a digital to analogue converter (DAC) IC from Microchip via an I2C interface. Compatible with MCP4706 (8-Bit), MCP4716 (10-Bit) and MCP4726 (12-Bit) devices.
Please click here for the component source code: FC_Comp_Source_DAC_MCP47x6.fcfx
SetOutput
Sets the output voltage of the DAC 8-Bit: Range 0-255 10-Bit: Range 0-1023 12-Bit: Range 0-4095
- UINT DAC_Value
The value to output to the DAC
Disable
Disables the DAC output.
Enable
Enables the DAC Output.
Configures the I2C peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated.
DAC IC
Selects which DAC IC is connected and therefore the bit depth available.
Disabled Pull Down
Sets the pull down resistance when the IC's DAC output is disabled.
Voltage Reference
Sets the Voltage reference option
Gain Option
Provides a 1x or 2x gain on the output. For 2x gain the vref must be max 1/2 VCC.
Vref Voltage
Steps
Number of discrete output states available from the DAC.
Control Bits
Resolution
Voltage Resolution
I2C Connections
User Address Bits
Specifies the bottom three "user" bits of the I2C 7-bit address
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
Simulate Comms
