Component: DMX-512 Slave (Comms: System)
Author | MatrixTSL |
Version | 2.0 |
Category | Comms: System |
DMX-512 Slave component
A serial based communications protocol designed for controlling theatrical equipment such as dimmers, fog machines and intelligent lights. DMX-512 Slave devices are daisy chained together with a final 180R terminating resistor at the end of the chail. DMX requires the signal to be level shifted from VCC and GND to +2.5V and -2.5V.
Please click here for the component source code: FC_Comp_Source_DMX-512_Slave.fcfx
DMX Slave Example, captures the first DMX data channel sent from the Master and outputs the value onto a Port using the LED array component. DMX Slave Example1
For DMX 512 Master example see Component: DMX 512 Master (Comms: System)
GetDataChannel | |
Gets the data byte from a data channel | |
- UINT | Channel |
- BYTE | Return |
Initialise | |
Configures the UART serial interface. | |
- VOID | Return |
