Component: DSPBuffer (DSP)
Revision as of 14:39, 16 January 2023 by Wiki bot (talk | contribs)
Category DSP
DSPBuffer component
Creates a DSP buffer to be embedded into a DSP component to hold any output values.
Please click here for the component source code: FC_Comp_Source_DSP_Buff.fcfx
Some examples containing the Input ADC component.
On Off Control
PID Control
Prv_PutPropStr
- UINT Idx
- UINT Val
Prv_PutConsole
- UINT Idx
- LONG Val
get
Embedded - Get/Set uses Type Specified to maintain efficiency Sim - Reverts to long type so 8/16 bit will also fit
- UINT idx
- LONG Return
put
- UINT idx
- LONG val
put_float
- UINT idx
- FLOAT val
Prv_GetPropStr
- UINT Idx
Prv_GetConsole
- UINT Idx
- LONG Return
get_float
- UINT idx
- FLOAT Return
Val
Parent Name
Buffer Size
Buffer Type
Data Recorder Trace
Console
Console Size
Text
Orientation
Enabled
