Component: On/Off Control (DSP Operators)
Revision as of 14:39, 16 January 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.2 |- | width="20%" style="color:gray...")
Version 1.2
Category DSP Operators
On/Off Control component
On/Off Control - Standard on off control as used on most ovens, toasters, irons.
Please click here for the component source code: FC_Comp_Source_DSP_OnOffControl.fcfx
Here is a project file showing an on off control system for a system such as an electric oven.
The setpoint is set via an analogue input which controls the desired temperature of the system.
In this first example the feedback is provided using the simulated load DSP component which simply takes a percentage of the last output and combines with a percentage of the new output.
This allows easy moddeling of systems such as ovens that heat up and cool down over time which allows you to see the system in action.
You assign a setpoint and then the system will get to temperature and then maintain the output by automatically switching the output on and off.
When the feedback is less then the setpoint minus the hysteresis then the output is switched on.
When the feedback is more then the setpoint then the output is switched off.
FC6 Icon.png On Off Control Simulated Output Example
In this second example the feedback is provided via a temperature sensor component. This shows how you would do it with a real system using a sensor to complete the feedback loop.
FC6 Icon.png On Off Control Example
As with other DSP components the raw signals and values can be seen in the data recorder and console windows.
Fc9-comp-macro.png Process
Processes the current value from a buffer.
Fc9-comp-macro.png ProcessArray
Processes an entire buffer, either by performing the control operation to every value in the buffer or just the last value.
Fc9-type-16-icon.png Setpoint Connect To
Fc9-type-16-icon.png Feedback Connect To
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type.
Fc9-conn-icon.png Control
Fc9-type-14-icon.png Hysteresis
Minimum variation before the output will be allowed to switch state. Used to avoid high frequency oscillation on the control output.
Fc9-type-14-icon.png On Value
Value passed to the output buffer when the control output is active or on.
Fc9-type-14-icon.png Off Value
Value passed to the output buffer when the control output is not active or off.
