Component: E-block 2 Helper (E-blocks 2)
Revision as of 14:40, 16 January 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.1 |- | width="20%" style="color:gray...")
Version 1.1
Category E-blocks 2
E-block 2 Helper component
A purely cosmetic component to help simplify E-block 2 connections without having to keep referring to the datasheets. Specify which E-block 2 board your using and the component will display the connections required.
Please click here for the component source code: FC_Comp_Source_E-block2_Helper.fcfx
E-block ID
E-block product ID
E-block Name
Cosmetic name of the E-block to confirm you have the correct board.
Connections Port 1
Bit 0
Port 1 Bit 0
Bit 1
Port 1 Bit 1
Bit 2
Port 1 Bit 2
Bit 3
Port 1 Bit 3
Bit 4
Port 1 Bit 4
Bit 5
Port 1 Bit 5
Bit 6
Port 1 Bit 6
Bit 7
Port 1 Bit 7
Connections Port 2
Bit 0
Port 2 Bit 0
Bit 1
Port 2 Bit 1
Bit 2
Port 2 Bit 2
Bit 3
Port 2 Bit 3
Bit 4
Port 2 Bit 4
Bit 5
Port 2 Bit 5
Bit 6
Port 2 Bit 6
Bit 7
Port 2 Bit 7
