Component: Electrical Machines (AllCode)
Revision as of 14:40, 16 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category AllCode
Electrical Machines component
A set of functions to communicate with the Matrix EM hardware. Allows the functions to be easily standardised across all SCADA programs.
Please click here for the component source code: FC_Comp_Source_EM_Functions.fcsx
GetLogDataReady
Checks to see if the logging is complete and ready to read.
- BOOL Return
GetRPM
Reads the speed in RPM
GetWeight
Reads the voltage of a single channel
- BYTE Scale
Range: 0-1 - 0=Weight, 1=Torque
- FLOAT Return
SetControlKP
- FLOAT Value
SetControlSetpoint
- FLOAT Value
GetAPIVersion
Reads the API firmware version
GetLogData
Gets a 64-byte packet of log data. 250 packets make up a single log. Returns 0 if comms failed and 1 if comms OK
- BYTE Buffer
Buffer to store the incoming log data
- BOOL Return
GetDataArray
Collects a data array from the EM box full of control data. Each set of data includes: Setpoint, Feedback, Poutput, Ioutput, Doutput Returns the number of complete data samples collected.
- FLOAT data
GetSafetySwitch
Reads the safety switch
SetControlKI
- FLOAT Value
ZeroLoadCell
SetControlMaxDrivePercentage
- FLOAT Value
Range 0.0-1.0
SetMotorType
- BYTE MotorType
0=DC, 1=1 Phase, 2=3 Phase
SetLoadCellCalibration
- FLOAT Value
GetVoltage
- BYTE Channel
Range: 0-5 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=VEXT
- FLOAT Return
GetControlFeedback
- FLOAT Return
SetControlKD
- FLOAT Value
SetCapacitorBank
- BYTE Cap
GetCommsOK
Checks if comms are ok and stable
- BOOL Return
GetLogStartAngle
Collects the U Phase angle at the start of logging. Used to calculate and re-create the 3Phase voltage data.
SetVoltage
Sets the DC Voltage from 0 to 24V
- FLOAT Voltage
- BYTE Index
Get3PhaseMode
Checks to see if the brushless mode is enabled
- BOOL Return
GetAbsPosition
Reads the absolute position of the encoder
- ULONG Return
SetFan
|Sets the speed of the FAN from 0 (MIN) to 3000 (MAX)
- UINT Speed
SetMotorDirection
- BOOL MotorDirection
0=FW, 1=BW
GetMotorDirection
Reads the motor direction
SetThreePhaseDriveMode
- BOOL Mode
0=Simple, 1=Accurate
GetCurrent
Reads the current of a single channel
- BYTE Channel
Range: 0-6 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=Dyno, 6=I, 7=TotalDriver
- FLOAT Return
SetFrequency
- UINT Frequency
Frequency of sine wave in Hz
SetDynoLoad
- FLOAT Load
GetErrorStatus
Gets the current error status. Error status will automatically resolve itself once the causing condition has been removed. 0 = No Error 1 = Error - likely over current or brownout
GetControlOutputs
- FLOAT Data
SetActive
- BOOL Active
0=Off, 1=On
SetDriveMode
- BYTE Mode
0=PWM, 1=On/Off/Float
SetTCPProps
Sets the TCP IP address and Port
- BYTE IP0
- BYTE IP1
- BYTE IP2
- BYTE IP3
- UINT Port
SetAbsPosition
Resets the absolute motor position to 0
Returns 1 if the connection is ok and communications have been established
- BYTE MotorType
0=DC, 1=1Phase, 2=3Phase, 3=AngleControl
- BOOL Return
Communications
Comms Mode
Stop On Error
Automatically allows the runtime to stop if there is a communications error.
USB Communications
Autodetect Port
Runtime Statistics
Allow console data to be generated showing the high level EM communications and returns
