API Panel.Collision.GetSinglePos
Revision as of 13:14, 14 May 2013 by JonnyW (talk | contribs) (XML import API changes)
<sidebar>API contents</sidebar> Returns the position to move Pos to so it does not collide with Test - null if no collide
Class hierarchy
Panel
Collision
GetSinglePos
HANDLE Pos
A component or position to focus the collision around
HANDLE Test
An object to test collisions with
HANDLE MoveAxis
The position whose axis will be moved along on collide
HANDLE
  • Add to a calculation icon:
    result = ::Panel.Collision.GetSinglePos(pos, test, moveaxis)
