Author
Matrix TSL
Version
2.0
Category
Misc
I2C component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Two Wire I²C peripheral.
Please click here for the component source code: FC_Comp_Source_I2C.fcfx
Slave_Uninit
Uninitialise the Slave
GetValue
Get the Named property value.
- STRING
Name
- STRING
Transaction_Write
Attempt to write Length number of bytes to the I2C slave from the given Buffer. Ensure that the Buffer is large enough. Returns the number of bytes written, the caller should check that this matches requested Length
- BYTE
Buffer
Buffer of bytes to write to the I2C
- UINT
Length
- UINT
Master_Stop
Output a Master Stop
Slave_Init
Initialise the Slave with the given Address, or range of Addresses. Only address bits that have a corresponding bit set in the Mask will be compared with the incoming bus address.
- BYTE
Address
7 Bit Address of this device (Bit 0 is ignored)
- BYTE
Mask
Bit mask used to compare addresses
Master_Uninit
Uninitialise the Master
Slave_Status
Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
- BYTE
GetConsoleHandle
Obtains the CAL console handle
- HANDLE
Slave_TxByte
Send a data byte, returns Ack/Nak from Master 0=Ack=More, 1=Nak=Last
- BYTE
Data
- BYTE
Transaction_Uninit
Uninitialise the I2C interface
Slave_RxByte
Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
- BYTE
Last
Sends Ack if 0, else Nak
- BYTE
SetValue
Change Named property to new Value. If "CHANNEL" the ports will be also updated from the fcd
- STRING
Name
- STRING
Value
port value as string
Master_Init
Initialise the Master
Master_Start
Output a Master Start sequence
Transaction_Read
Attempt to read Length number of bytes from the I2C slave to the given Buffer. Ensure that the Buffer is large enough. Returns number of bytes read, caller should check that this matches requested Length
- BYTE
Buffer
Buffer to store the incoming byte data
- UINT
Length
Number of bytes to read
- UINT
Master_TxByte
Send a data byte and collects the acknowledge from the slave. Returns 0 for Ack received. Returns 1 for Ack not received - slave not responding.
- BYTE
Data
Data byte to write to the I2C bus
- BYTE
Master_Restart
Output a Master Restart sequence
Master_RxByte
Returns a received data byte. Set Last=0 if there is following more Master_RxByte macros Set Last=1 if this is the last Master_RxByte and it is followed with Master_Stop. If Last = 1 the I2C bus will be presented with a 'Nack' condition.
- BYTE
Last
Range: 0-1 - 0 = Not the last byte to receive, 1 = last byte to receive
- BYTE
Transaction_Initialise
Initialise the I2C interface to communicate with a Slave device at Address Returns 0 on fail, 1 on success
- BYTE
Address
7-bit I2C Address without the shift for the R/W bit
- BYTE
GetList
returns Named property List as filter string
- STRING
Name
- STRING
Component Enable
Allows the component to be easily disabled from generating code, allowing for multiple CAL components to be easily created. For example a sensor IC with both I2C and SPI communications interfaces.
Channel selection
Mode
Defines if the component will be used for Master or Slave communications. Master mode supports a software bitbanged I2C channel. Slave mode requires a hardware I2C peripheral to catch the communications from the Master.
SDA
SCL
Options
Stop Delay
Baud Select
Baud rate to be used
Slew Rate Control
Slew Rate Control Enabled or Disabled
SMBus Inputs
When Enabled input logic thresholds are compliant with SMBus specification
API
Specifies the API component on the panel to interact with to provide comms simulation.
