Component: I2C Slave (Comms: Interface)
Revision as of 14:41, 16 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.3
Category Comms: Interface
I2C Slave component
Please click here for the component source code: FC_Comp_Source_I2C_Slave.fcfx
PIC16F1937 Examples
The slave device is connected to a bank of switches, the master device to a bank of LEDs. The value of the switches is passed to the master LEDs. FC6 Icon.png Master Read Example
FC6 Icon.png Slave Switches Example The slave device is connected to a bank of LEDs, the master device to a bank of switches. The value of the switches is passed to the slave LEDs. FC6 Icon.png Master Send Example
FC6 Icon.png Slave LEDs Example
Arduino Uno Examples
Example program showing how to use the I2C Slave on an AVR Arduino device. FC6 Icon.png I2C Slave Arduino Uno Example
ECIO40P Examples
Example program showing how to use the I2C Slave on an ECIO40P device. FC6 Icon.png Master Example
FC6 Icon.png Slave Example
Fc9-comp-macro.png ReceiveByte
Receives a byte from the I²C bus. Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
Fc9-u8-icon.png - BYTE Last
Used to signify the last byte when streaming incoming data. 0=Not last byte, 1=Last Byte
Fc9-comp-macro.png TransmitByte
Sends a byte on the I²C bus. Returns the acknowledge if any. 0 represents that data was acknowledged and 1 represents no acknowledge was detected.
Fc9-u8-icon.png - BYTE Data
Data byte to send on the I²C bus.
Fc9-comp-macro.png Check_Status
Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
Fc9-comp-macro.png Initialise
Enables the I²C hardware and performs some initialization. Should be called at the start of the program or at least before any of the other I²C functions are called.
Fc9-conn-icon.png Bus Settings
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-conn-icon.png Slave Setttings
Fc9-type-21-icon.png Slave Address
Fc9-type-21-icon.png Mask
0 - don't care; 1 - perform match; So address of 0x30 and mask of 0xF0 will allow the slave to respond to addresses of 0x30, 0x31, 0x32, …, 0x3F
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Label shown on the comms flasher on the simulation panel.
Fc9-type-16-icon.png API
