Component: Injector (Human Interface) (Test Injectors)
Revision as of 14:41, 16 January 2023 by Wiki bot (talk | contribs)
Category Test Injectors
Injector (Human Interface) component
Comms data injector to allow typed data values to be inserted into a component. Allows data to be input in raw ASCII form or as numeric byte data 0-255.
Please click here for the component source code: FC_Comp_Source_InjectorHI.fcfx
This example receives a character via the RS232 component and outputs it to the LCD, an injector has been added to allow you to type data into the console. Human Interface Injector Example The Console window has tabs for the human interface data injector allowing you to type in data that will be received by the component.
Again the RS232 console tabs reflect the data as it is sent and received.
LCD showing received data.
UARTBaud
- BYTE Channel
- BYTE Rate
IOGetInputPin
- BYTE Pin
Range: 0-19
- BOOL Return
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
GetConsoleHandle
- HANDLE Return
UARTReceive
- BYTE Channel
IOSetOutputPin
- BYTE Pin
Range: 0-53
- BOOL State
Range: 0-1
UARTSend
- BYTE Channel
- BYTE Data
HI Injector Settings
Buffer Size
Max number of bytes that can be stored in the components circular buffer
Data Mode
Sets the console data to interperete the data as ASCII or as Numbers 0-255
label
Show Console
