Component: IrDA (EB012, MCP1250, MCP2120) (Wireless)
Revision as of 14:41, 16 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Wireless
IrDA (EB012, MCP1250, MCP2120) component
Low level routines for controlling a standard IrDA interface. Also available in the form of the EB012 IrDA E-block.
Please click here for the component source code: FC_Comp_Source_IrDA.fcfx
Transmit
Basic example which repeatedly transmits a string of data via the IrDA interface. IrDA Transmit
Receive
Basic example which waits for any incoming data and then displays the data on the LCD. IrDA Receive
SendChar
Sends a byte character to the IrDA connection.
- INT Char
ReceiveChar
Receives byte character from the IrDA connection.
- INT Timeout
Max amount of time in milliseconds to wait for data.
- INT Return
Initialises the UART ready for IrDA data to be sent or received,
Comms Settings
Interface
Decides which IrDA interface IC we wish to communicate via.
Baud Options
Data Bits
Number of data bits
Echo
Echo selection
TX
RX
Use Flow Control
Console Columns
Data Source
